Mismatch between Paper Space linetype scale and Model Space linetype scale
I think I have a partial answer for this problem, which has been raised by a number of others over quite a few years. What it boils down to is incomplete programming objectives. It is absolutely possible to program linetypes to have the same appearance in both MS and PS without the solution I provide next.
If, for example, you wish the line type to be the same in Paper Space you must first turn off MS linetype (MSLTYPE=0). Assuming you created your model first with the linetype you wanted shown, then you have to go to Paper Space making sure PSLTYPE=1. If it doesn’t show correctly then adjust the LTSCALE until it appears as it should.
This is a VERY POOR way to arrive at the correct results, AND it has been going on for YEARS. It is time spent that will be questioned by those you work for, unfairly and most likely. Part of the reason for this is contained in your printer software. It has to be set to the correct media size output first. The printer software, when set to the media size, should result in linetype scales that show correctly AUTOMATICALLY within the software.
