How to remove trailing zeros on Zero Tolerance Dimesion 0.0
aky
aky
Hello
How can I remove the trailing zeros on zero in tolerance?
For example)
89.0 +1.0/0 shows up like this.
I want to keep +1.0 and Remove the trailing Zero on 0.0. Just want it to show 0I want to keep +1.0 and Remove the trailing Zero on 0.0. Just want it to show 0
I want to get rid of the trailing zero on just the 0.0
How can I do this?
Thanks!
VinodBalasubramanian
Autodesk Support
Autodesk Support
You can type DIMSTYLE in the command line and change the precision in tolerance tab. Check the picture below.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
