AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Feature Control Frame Leader
3 REPLIES 3
Thalmet
446 Views, 3 Replies
I for the life of me cannot figure out how to fix the leader of the Feature Control Frames in AutoCAD Mechanical 2020.  Any time myself or a student selects an object with the FCF it will only allow the leader to go either vertical or horizontal.  It will not allow it to be angled.  HOWEVER, if I don't select an object I can create an angled leader with my FCF.  How do I fix this?
3 REPLIES 3
Thalmet
in reply to: Thalmet
I'll also add that turning Ortho Mode on or off does nothing to change this.
bigcarl5000kg
Hi @Thalmet ,
maybe here: https://knowledge.autodesk.com/support/autocad-mechanical/learn-explore/caas/CloudHelp/cloudhelp/202...
Can you post here an example?
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Thalmet
in reply to: bigcarl5000kg
THANK YOU!  I have searched forever trying to find this!  Shift+F works!  You are a saint!
