I for the life of me cannot figure out how to fix the leader of the Feature Control Frames in AutoCAD Mechanical 2020. Any time myself or a student selects an object with the FCF it will only allow the leader to go either vertical or horizontal. It will not allow it to be angled. HOWEVER, if I don't select an object I can create an angled leader with my FCF. How do I fix this?
Solved by bigcarl5000kg. Go to Solution.
Hi @Thalmet ,
maybe here: https://knowledge.autodesk.com/support/autocad-mechanical/learn-explore/caas/CloudHelp/cloudhelp/202...
Can you post here an example?
THANK YOU! I have searched forever trying to find this! Shift+F works! You are a saint!
