Dimensions are offset from object when placed
Hello everyone,
I have anunecpected behaviour of dimensions in AutoCAD Mechanical 2018. Whgen I'm trying to mark dimensions of our product, the dimensions are umped aside. For better explanation, I'll upload a few pictures:
I'm not even able to replace the dimension manually.
I'm quite convinced, that it is caused by the setting, but I haven't found out, where to change it.
Tahks for your help!
Have a nice day,
Adam
[The subject line of this post has been edited for clarity by cheryl.buck from: Dimensions are defaultly jumped aside]
pendean
Community Legend
Community Legend
post your dwg if you are still trying to solve this one.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
That sounds very frustrating, and looks like a graphics display error. Does turning off Hardware Acceleration help?
How to enable or disable hardware acceleration in AutoCAD
If the issue is display related, updating the video card drivers, and making sure the discreet card is being used (rather than the on board one) often helps. Video card driver updates can be downloaded from the manufactures website. See the following common links:
NVIDIA Driver Download
AMD Driver Download
Intel Driver Update Utility
Please let me know if this resolved the issue.
All the best,
If a post was helpful, Likes are always welcome.
Please select the Accept as Solution button on the post(s) that answered your question or solved the problem.
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am checking back to see if my post helped you with your problem.
Please post an update letting the community know if you were able to resolve the issue.
All the best,
Cheryl Buck
sorry for the delayed answer.
I tried your recommendation and it helped.
Thank you,
A.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
That's great news! Thank you for coming back to post and letting me know.
All the best,
Cheryl Buck
