Hello to everyone,
I have a problem creating a new layer from excel VBA.
This is the code. Last if statements is wrong.
Sub New_Layer() Dim acadApp As AcadApplication Dim acadDoc As AcadDocument Dim newLayer As AcadLayer Dim layerName As String 'Check if AutoCAD is open. On Error Resume Next Set acadApp = GetObject(, "AutoCAD.Application") On Error GoTo 0 'If AutoCAD is not opened create a new instance and make it visible. If acadApp Is Nothing Then Set acadApp = New AcadApplication acadApp.Visible = True End If 'Check if there is an active drawing. On Error Resume Next Set acadDoc = acadApp.ActiveDocument On Error GoTo 0 'No active drawing found. Create a new one. If acadDoc Is Nothing Then Set acadDoc = acadApp.Documents.Add acadApp.Visible = True End If 'check to see if layer already exists and if not make a new On Error Resume Next layerName = "Layer_1" Set newLayer = ThisDrawing.Layers.Add(layerName) newLayer.Color = acBlue On Error GoTo 0 If newLayer Is Nothing Then Set newLayer = ThisDrawing.Layers.Add(layerName) 'Here I have error Object required End If End Sub
If someone can help me I will be very appreciative.
Hello to everyone,
Solved!!!
Sub New_Layer() Dim acadApp As AcadApplication Dim acadDoc As AcadDocument Dim newLayer As AcadLayer Dim layerName As String 'Check if AutoCAD is open. On Error Resume Next Set acadApp = GetObject(, "AutoCAD.Application") On Error GoTo 0 'If AutoCAD is not opened create a new instance and make it visible. If acadApp Is Nothing Then Set acadApp = New AcadApplication acadApp.Visible = True End If 'Check if there is an active drawing. On Error Resume Next Set acadDoc = acadApp.ActiveDocument On Error GoTo 0 'No active drawing found. Create a new one. If acadDoc Is Nothing Then Set acadDoc = acadApp.Documents.Add acadApp.Visible = True End If 'check to see if layer already exists and if not make a new On Error Resume Next layerName = "Layer_1" Set newLayer = acadDoc.Layers.Add(layerName) newLayer.Color = acBlue On Error GoTo 0 If newLayer Is Nothing Then Set newLayer = acadDoc.Layers.Add(layerName) End If acadDoc.ActiveLayer = newLayer End Sub
Solved!!!
Hi @Anonymous,
Thank you for returning and adding a post with the Solution.
Please select the Accept as Solution button on your post so other members of the community can more easily find the solution.
All the best.
Hi @Anonymous,
All the best.
@ahmedmontaser504 wrote:
I want acode that make layer isolate to active layer
https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-E24B9866-9538-43BF-A3DF-AA7E2341C624
