How to stop "highlighting" when I hover over objects.
Message 1 of 8
Every time my cursor goes over an item, the item highlights.  How to stop "highlighting" when I hover over objects.
Replies (7)
Message 2 of 8
gaurav.satalkar
You can stop the object highlighting after cursor hovering by changing the value of the system variable SELECTIONPREVIEW to 0 (zero).
If you need other options with the selection preview, please check this link:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Hope this helps.
Please select the Accept as Solution button if my post solves your issue or answers your question.
Thank You,
Gaurav Satalkar
QA Engineer
Message 3 of 8
anung_rama
Community Visitor
Community Visitor
NOPE, DIDNT CHANGE A THING
Message 4 of 8
zahidq2002
Community Visitor
Community Visitor
Same didn’t work , just found out when hovering it  selected everything still. The solution is let it select everything then type is explode , and it should do the trick
Message 5 of 8
efaruque
Observer
Observer
Accepted as solution.
Message 6 of 8
ccamarilloB86YG
How do I turn the highlight off when I am in an active command? for example, I have a 3d object in wireframe view and I'm trying to select a circle inside a 3d solid box in wireframe view, but it highlights the surface of the solid box and does not let me select the circle. Thanks in advance. The solution provided here does not fix my issue by the way.
Message 7 of 8
kathy_spaw
Observer
Observer
Tools > options > selection tab > preview pane > deselect "when a command is active" and "when no command is active."
Message 8 of 8
ccamarilloB86YG
did that and it didn't turn it off. It only does it over 3d objects. It use to not do it when I had 3d objects in wireframe mode. not 2d wireframe but just wireframe visual style.
