change Mechanical Save as default version programmatically
Michael_Zindath
Michael_Zindath
I would like to set the default save version to a specific Version via lisp.
When I try to access this through (getenv "DefaultFormatForSave") I always get 64 for mechanical versions 2018-2025. Only when going lower then that I see a change. So this environment variable seems to only track the Major dwg revisions and not mechancial versions.
Where is this information stored and how can I change it?
pendean
Community Legend
Community Legend
Dumb question if I may: is this a constant need to change on the fly while in DWG file?
In Plain AutoCAD... 64 represents the common DWG format changed between versions 2018-19-20-21-22-23-24-25.
That should change for 2013-14-15-16-17
then again for 201-11-12
and so on.
MECH year-versions are ignored.
Michael_Zindath
Fair question.
I would like to ensure that the mechanical version is set correctly for all my collogues. So that normal open and save operations keep the desired ODA mechanical Version.
