Cannot Etransmit
Cannot Etransmit
ekreps7T53Q
Message 1 of 8
Cannot Etransmit
ekreps7T53Q
E-Transmitt will not allow me to bind in AutoCAD Mech 2016. The option is there but it is grayed out. anyone know why?
[The subject line of this post has been edited for clarity by cheryl.buck]
Replies (7)
Message 2 of 8
Sridhar-Autodesk
Hi
One reason I see is; AutoCAD mechanical has Structure workflow.  If a structure drawing is xrefed in to another drawing and if the xref drawing is Xref-binded, the structure intelligence is lost.  There won't be any relation between different views created in the structure workflow.
Sridhar Subramani
Senior Product Owner
Message 3 of 8
ekreps7T53Q
I am not sure I understand the structured work flow. this I a drawing or a number of drawing not bound into another drawing not bound into it yet. so as I am working on this drawing there are live xrefs.When I am finished with the drawing I want to copy to another directory bound because customers will not be able to have access to the drawings that are Xrefed. I can manually bind the drawing but many times there are many drawings to bind and the only whey I know is to do it in e-transmit as I did before 2016 but now I cannot
Message 4 of 8
Sridhar-Autodesk
Hi
You may either launch AutoCAD profile from Windows>>Start>>Programs>>Autodesk>>AutoCAD Mechanical >>AutoCAD, open the drawing file and use Etransmit.
OR in Mechanical, you can bind multiple files at a time in the Xref Palette.
Open Xref Palette>>Select all the drawing >>Right mouse click and select Bind
Hope this helps
Sridhar Subramani
Message 5 of 8
cheryl.buck
Autodesk Support
Autodesk Support
Hi @ekreps7T53Q.
Did @Sridhar-Autodesk resolve your issue with his great suggestion? If so, please reward poster with a Kudos and please also mark the post as Accepted Solution.
All the best.
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 6 of 8
ekreps7T53Q
Thank you Sridhar,
Launching Acad from the start menu worked great. I still need to try to save that as a profile so I do not need to launch from the start menu every time I want to use E- Transmit, but at least I can Bind with E-Transmit.
Message 7 of 8
Sridhar-Autodesk
@ekreps7T53Q
You may right click on Acad icon in the start menu>>Send to>>Desktop (Shortcut)
Sridhar Subramani
Message 8 of 8
cheryl.buck
Autodesk Support
Autodesk Support
Hello @ekreps7T53Q,
Thank you for the added info on your issue. If that last great suggestion by @Sridhar-Autodesk also solves your issue, you may mark it Accept As Solution as well.
Hope you see you in the forums again.
All the best,
Cheryl Buck
