Hi All,
I am using 2018 version AutoCAD Mechanical. I want to know if its any way (via settings or command) that I can make the paper space look in monochrome view while keeping colours in model space? Until I create pdf with monochrome settings, I cant seem to see things and sometimes, the text on the edges gets cut/trim when printed.
See the screenshot. Also, is there a way I can change setting where model space is in white instead of black or paper space as black ? See attached image.
Yash
Solved by pendean. Go to Solution.
Solved by cheryl.buck. Go to Solution.
Hi Pendean,
Thank you very much. It worked. How do I make it as permanent setting instead of typing command every time ? If I choose option "set it as current", will it be applicable to all or there is something like template where I can set ?
Yash
Hi @Yashasvi23481,
I am very glad the post by @pendean helped with your monochrome question. It will be applicable to the layout you set up, or any layouts that use that named page setup. See About Named Page Setups.
On your question regarding changing the background color of your model space or layout space, this can be done in OPTIONS:
Please let me know if this helps.
All the best,
Hi @Yashasvi23481,
You are so very welcome. Have a great rest of your week!
Please advise.
Someone set PS to be monochrome, I want to undo the PS monochrome back to see the colors.
Regards
Antonio
Hi @perezaUVERF,
You can change the color back to white. please follow the screenshot above by Cheryl.
Options > Display tab > Colors > 2D modelspace > Uniform background > color (change to white) > Apply and close.
Let us know if this answers your question.
Thank you for your reply.
My issue is the drawing I'm working in, it was set as follows:
Model Space = uniform background is black, drawing line work is in colors set by layer or assigned. (This is fine)
Paper Space = uniform background is black, drawing white line work no colors visible. (This should not be monochrome)
There must be a setting or configuration for paper space drawing line work to be all white, someone set it to be all white line work. I want to undo it.
There are no other drawings set the way unfortunately the person that did this no longer works here either!!!
Can't find anything on the internet to undo this.
Antonio
@perezaUVERF wrote:
...There must be a setting or configuration for paper space drawing line work to be all white, someone set it to be all white line work. I want to undo it.
Can't find anything on the internet to undo this....
Uncheck this box in PAGESETUP for each paperspace tab you want to change
HTH
God..
Thank You Sooooo much !!!👍
I had this happen years ago and could not remember that very obscure setting.
I'm writing it down
Again Thank you!!!!
The background should be white but the xref need to be monochrome and that is not working
