AutoCAD freezes when entering cartesian coordinate
We recently installed AutoCAD Mechanical 2020.  Every time I draw a line, or rectangle I attempt to use the cartesian coordinate as with previous versions of AutoCAD.  I type in "rectang" and select a point on the screen.  then type "@24,6".  but the command freezes.  I press escape a number of times but the command will not release.  the only way I have found to interrupt the command is to restart the program.  So I have several questions
1. has the cartesian coordinate function changed, the prompts do not appear to be different?
2. why does the escape not work to release the command line?
I have attached a screenshot of the dynamic curser.  incidentally, I am unable to type any value in that dialog
Jason.Rugg
@AnonymousTry running a repair on your ACAD installation, this should take care of it.
