auto number
auto number
auto number
help please
autocad 2016
I am wanting to auto number but within brackets    ie     (10)  (11)  (12)   etc
any ideas    ive tried tcount   but cant get it to do it
BeKirra
This AutoCAD version doesn't provide the actual function that you requested.
However, you may search through the net and will be able to get some add-on programs to do what you want.
BTW, you may also post your question in AutoLisp forum below so people may give you more helps.
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
