AMFILLET2D command not found in AutoCAD Mechanical 2016
we have facing below error on auto cad 2016 mechanical
_amfillet2d unknown command "AMFILLET2D" . PRESS F1 FOR HELP
[This post has been edited and the title has been updated for clarity by cheryl.buck Autocad 2016 ( _amfillet2d unknown command "AMFILLET2D" . PRESS F1 FOR HELP )]
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD Mechanical forum. Welcome to the Autodesk Community!
Can you tell me the steps you are taking prior to the error occurring? A screen shot of the drawing and showing the area you are trying to fillet would also help.
Often when an AutoCAD Mechanical specific command cannot be found it is because Mechanical is not open. Can you also double check that you did open AutoCAD Mechanical rather than Vanilla AutoCAD? This can be checked in the program window (center title bar) or in OPTIONS under Profiles (ACADMPP for Mechanical)
All the best,
If a post was helpful, Likes are always welcome.
Please select the Accept as Solution button on the post(s) that answered your question or solved the problem.
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am checking back to see if my post helped with the AMFILLET2D command error.
Please post an update letting the community know if you were able to resolve the issue.
All the best,
Cheryl Buck
