Dear Sir,
Please suggest how to add number of sheets in Autocad.
I have to create 20 sheets and how to print these 20 sheets at a time.
Please provide me the guidance to do if it is possible.
Narendra.
[The subject line of this post has been edited for clarity by cheryl.buck from: Adding sheets in Auto CAD]
Solved by cheryl.buck. Go to Solution.
Write more precisely - what uvas is.
Do you have a dwg drawing?
Dear Sir,
I am having a dwg drawing file.
I want to create 20 dwg drawing files as sheet 1 to sheet 20.
And I want to print these 20 dwg drawing files at a time.
Please suggest.
Narendra.
Do you have 20 title blocks per model?
Show us pictures of your screen or give your file.
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD Mechanical forum. Welcome to the Autodesk Community!
There are a couple methods for doing this.
Please let me know if this helped.
If a post was helpful, Likes are always welcome.
Please Accept As Solution any post(s) that answer your question or solve the problem.
All the best,
[This post has been edited for clarity by cheryl.buck]
Hi Narendra,
Use Viewports to create drawing sheets from model space to paper space. Once you do that with title block. Select all 20 sheets on tabs, and right click publish these sheets only. It takes you to multi sheet publishing option. Give it drawing number and select folder. It will create pdf as 1 file. Please see attached pdf for step by step process with screenshots.
Ensure you have settings for pdf esp with lineweights taken off or someline will be very heavy.
Hope it helps.
yash.
Hi Narendra,
Forgot to mention, you can add sheets by choosing from template on the tabs. you will be provided by 2 blank tabs as layout 1 and layout 2. but if not, right click on model space, and first option is from template. I am assuming you have set title blocks and templates pre existing.
Once Pdf is generated as 1 file with multiple sheets, you can print all as normal.
Yash
Hi @Anonymous,
I am checking back to see if you were able to resolve your issue or if one or more of the posts in this thread helped you with your problem.
Please post an update letting the community know if you were able to resolve the issue.
All the best,
Hi @Anonymous,
If you would like me to take a look at the file to determine specific options for you, please attach the file in the thread and give a detailed explanation of what views and how you are trying to plot/publish them.
All the best,
Dear Madam,
I have attached two drawings templates in dwg format size A3.
Please explain me how to batch plot the two drawings.
If two drawing template dwg files are in same model then is it possible to print two templates at a time or not.
Narendra.
@cheryl.buck wrote:
Hi @Anonymous,
All the best,
