AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Adding sheets and plotting in AutoCAD
9 REPLIES 9
Message 1 of 10
539 Views, 9 Replies
Dear Sir,
Please suggest how to add number of sheets in Autocad.
I have to create 20 sheets and how to print these 20 sheets at a time.
Please provide me the guidance to do if it is possible.
Narendra.
[The subject line of this post has been edited for clarity by cheryl.buck from: Adding sheets in Auto CAD]
9 REPLIES 9
Message 2 of 10
maratovich
Write more precisely - what uvas is.
Do you have a dwg drawing?
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 3 of 10
in reply to: maratovich
Dear Sir,
I am having a dwg drawing  file.
I want to create 20 dwg drawing files as sheet 1 to sheet 20.
And I want to print these 20 dwg drawing files at a time.
Please suggest.
Narendra.
Message 4 of 10
maratovich
Do you have 20 title blocks per model?
Show us pictures of your screen or give your file.
www.kdmsoft.net
Message 5 of 10
cheryl.buck
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD Mechanical forum. Welcome to the Autodesk Community!
There are a couple methods for doing this.
  1. You could create 20 layouts in a drawing.  Draft in model space and set each layout to the appropriate model space using viewports. These layouts can then be plotted from a single drawing. See AutoCAD How to Create Layouts - New Layout Tutorial
  2. You could created a different drawing file for each sheet, and create Sheet Sets, which can be plotted. See
Please let me know if this helped.
If a post was helpful, Likes are always welcome.
Please Accept As Solution any post(s) that answer your question or solve the problem.
All the best,
[This post has been edited for clarity by cheryl.buck]
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 6 of 10
Yashasvi23481
Hi Narendra,
Use Viewports to create drawing sheets from model space to paper space. Once you do that with title block. Select all 20 sheets on tabs, and right click publish these sheets only. It takes you to multi sheet publishing option. Give it drawing number and select folder. It will create pdf as 1 file. Please see attached pdf for step by step process with screenshots.
Ensure you have settings for pdf esp with lineweights taken off or someline will be very heavy.
Hope it helps.
yash.
Message 7 of 10
Yashasvi23481
Hi Narendra,
    Forgot to mention, you can add sheets by choosing from template on the tabs. you will be provided by 2 blank tabs as layout 1 and layout 2. but if not, right click on model space, and first option is from template. I am assuming you have set title blocks and templates pre existing.
     Once Pdf is generated as 1 file with multiple sheets, you can print all as normal.
Yash
Message 8 of 10
cheryl.buck
Hi @Anonymous,
I am checking back to see if you were able to resolve your issue or if one or more of the posts in this thread helped you with your problem.
Please post an update letting the community know if you were able to resolve the issue.
All the best,
Cheryl Buck
Message 9 of 10
cheryl.buck
Hi @Anonymous,
If you would like me to take a look at the file to determine specific options for you, please attach the file in the thread and give a detailed explanation of what views and how you are trying to plot/publish them.
All the best,
Cheryl Buck
Message 10 of 10
in reply to: cheryl.buck
Dear Madam,
I have attached two drawings templates in dwg format size A3.
Please explain me how to batch plot the two drawings.
 If two drawing template dwg files are in same model  then is it possible to print two templates at a time or not.
Narendra.
@cheryl.buck wrote:
Hi @Anonymous,
All the best,
