Add Part number to Chain ISO 606
vali_dobrea
vali_dobrea
I need to add a new column for Part number, to ISO 606 chains type but there seems to be no direct access to the library as for the majority of the Mechanical Content. I need to map this column to the Part reference!
Currently working with 2019 version of the software!
Thanks !
gaurav.satalkar
You can edit the Standard content for Size or BOM Properties in Family table. You can edit the Standard content in Content Editor, and add a column in the Family table.
Hope this helps.
Thank you,
Gaurav Satalkar
QA Engineer
vali_dobrea
Unfortunately as it can be seen in the picture bellow there is no record in the family table from the Content
The picture from my first post is from the "Length calculation" tab. Could you please advice on the way I can Edit these type of products?
