It would be great to have an option during SCALE command that would ask you if you wish to also scale dimensions (if any has been selected) in selection set, and also when scaling blocks, cause now I have to use one lisp that I have to manually scale dimensions after scaling objects and it doesn't work on some dimensions and on ones that work, I have to adjust dimension scale overall and some other stuff in properties to display scaled dimensions properly...when you do this daily it takes up significant amount of time and would be great to have it in all versions of AutoCAD
