Match Property, Match Object Data
I would like a tool based on the "Match Property" form for Data Objects. It would be very useful to copy data from one geometry to another without the need to always type the data. Thank you
5 Comments
TerryDotson
If you were to consider third party add-ons, DotSoft's MapTools can copy object data (all tables) from one object to a selection set.
foxeec
Curious, are you looking for more than what the command 'copy_od' does?
Copy_od copies object data from one object to another.  Is there something more you want it to do?
Approve the idea.
We also had to spend their resources, we made four commands:
ODEDIT_COPY_OD - attach the same OD
ODEDIT_COPY_OD_VALUE - attach the same OD, transfer values
ODEDIT_COPY_ALL - attach the same OD and graphical properties
ODEDIT_COPY_ALL_VALUE - attach the same OD, transfer values and graphical properties
Now these commands (and many others) can be used - see the latest posts in the topic https://forums.autodesk.com/t5/autocad-map-3d-forum/additions-for-object-data/td-p/7548282
We added another command for this task - reading only the values, ODEDIT_COPY_VALUE.
See the latest posts at https://forums.autodesk.com/t5/autocad-map-3d-forum/additions-for-object-data/td-p/7548282
