Working version of AdministratorGuide.chm?
Peter2_1
Peter2_1
I have installed both versions of Infra Admin 2018 and 2020, German. Both have the same help file
"c:\Program Files\Autodesk\Autodesk Infrastructure Administrator 20..\Help\AdministratorGuide.chm         4356638       08.03.2016 07:37:44"
Both have the same problem described here (October 2016)
https://knowledge.autodesk.com/de/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/DEU...
the "solution" is:
Use an older version (which means 2013 or older).
So I would like to know:
a) Does it happen in other languages too?
b) Is the usage of version 2013 the one and only solution? 😯
c) Where to get version 2013?
AutoCAD Map 3D 2023 German / Oracle
sebastien.baudin
I can answer point a):
The same happens with the french version of M3D 2018.
Cheers,
Sébastien Baudin
swt-gis
I have no problem with  German version 2016 (Windows 7 and 10).
Peter2_1
@swt-gis
thanks, but your file is older and a little bit smaller.
Peter2_1
a) older version can be used.
b) Reported to Autodesk. Under development.
