Cannont Connect Data Sources
cedwards8511
cedwards8511
I had been running AutoCAD Map 3D 2019 on a computer with Windows 7.  Recently, I got a new computer with Windows 10, still running Map 2019, but I can't connect to any Data Sources in any of my dwgs.  When I go to the Data Link Properties, the Microsoft Office Access Database Engine is not listed (I had previously used Microsoft Office 12.0 Access Database Engine OLD DB Provider).
I have a bunch of utilities dwgs with Link Templates connecting blocks to databases (i.e. a stormwater map with manholes/inlets linked to an Access database with attribute data).  I created the links years ago and they have never failed me, now I'm lost without them.
I was hoping that it was something simple like installing an updated driver or something, but can't seem to figure it out.
Alfred.NESWADBA
Then you have not installed the Microsoft Access Database Engine 2016 driver.
You need to install >>>this<<<.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
cedwards8511
That was exactly what I needed.  Works great now.
I'm still a little confused why the AutoCAD Map article I found directed me to the 2010 version of the MS Access Engine instead of the 2016 version.  I went back to double check the age of the article, and it had a 2019 data.
