I am working on Swept Path Analysis for large loads and have been trying to use a WMTS. I have been able to connect to the server via MAPWSPACE. After pasting in the url and putting in the username and password, the data connection seems to work.
I can select the data to add to map, once highlighted it seems to add it, but when I zoon extents there is no visible map. Is there a setting I've missed because I've trawled the forums cannot find a fix.
Mike
Solved by creamcake33. Go to Solution.
I don't think zoom extents will generate a visible map, although it might if you wait a long, long time for the connection to regenerate. Try zooming-in to a smaller, tighter area to see whether the connection will give you visibility.....then zoom-out slowly to a wider area expanding the coverage so you find the limit where the connection cuts off. BTW, each time you zoom and pan the map will need to regen so use pan/zoom judiciously.
Chicagolooper
I didn't expect zoom extents to generate the map, I did that to search for it incase it popped in off screen. The problem is the map never appears.
Just to clarify, the drawing has been assigned coordinates, the Bing maps are visible in Geolocation. I just cannot see the map I tried to add using mapwspace data connect.
Turn on Bing Hybrid and use it as a guide, pan and zoom to your site. Draw a rectangle surrounding your site then zoom-in on the rectangle so it fills up most of your monitor then connect to your WMTS. Does the map connection appear inside the rectangle?
Chicagolooper
I turned on Hybrid, drew a rectangle zoom in etc, then connected to the WMTS nothing happened.
I have since tried other WMS and WMTS servers listed on GeoSeer and their maps have added without issues so it must be a problem with the WMS provider I used.
Hello
Just maybe a few "stupid" ideas :
1) Please set the correct Projection with the MAPCSASSIGN command
2) Zoom (please use GEOMAP to know where you are !?) to a 5km x 5km rectangle/square (where you have "data") ...
And then try to reconnect ...
The Health, Bye, Patrice (The Old French EE Froggy)
Patrice BRAUD
