Using the following command:
mapiinsert
in AutoCAD Map3D 2022.
The image places in the correct location, but renders in linear segments. They appear to be alternating upside-down, then right-side-up.
See below the image after mapiinsert (line segments), and the Map Aerial for reference from the same region of interest.
Figures: mapiinsert in Map3D_2022, versus the imagery from Map Aerial. The image appears to render incorrectly.
- The image itself is fine. Opening in other software, it is clearly not the image (tested with Windows Photo Viewer, Rhino3D, QGIS, and other versions of AutoCAD Map3D, namely 2019 and 2021).
- We also tried to debug any local settings which may have impacted this rendering error: drafting settings, for instance, Hardware Acceleration (tried with on and off).
We therefore believe this to be a bug in 2022. If anyone has suggestions on what might resolve this issue, besides Autodesk fixing a bug in 2022, I'm open to suggestions.
Patrick
