Wipeout plotting problems after reinstalling autocad map 3D 2018
Hi!
I have come across some problems after formatting the computer and reinstalling autocad 2018 Map 3D.
Problem: When i've plotted the drawing prior formatting the computer and reinstalling autocad this worked fine and the circular wipeouts did what they was supposed to do. But now in the layout tab they look like they do the job but when plotting they doesn't hide the background. The wierd thing is that the regular rectangular wipeouts works fine.
I've done circular wipeouts with this method:
1. Polygon command and added 360 as number of sides.
2. Wipeout command and then choose p and select the polygon.
3. Remove the polygon
4. Circular wipeout is complete and working fine
LayoutLayoutAfter plottingAfter plotting
I've tried searching around but haven't had any luck finding any solution. Any ideas what the problem can be?
And Im sorry for any misspellings and gramatical errors, english isn't my native language just my second 😉
Alfred.NESWADBA
verify with command _ABOUT that you have installed all updates:
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
