Acad.pgp - Command Alias Editor in Map 3D 2019
Upgraded finally from Map 2015 to Map 2019. I cannot get my acad.pgp from 2015 to migrate settings into the 2019 install.
Also tried using the Command Alias Editor in 2019 and will not save changes.  I'm a long time user (since Acad 12) and
usually have no problem getting my aliases over to new versions. Have already installed the 0.1 Update for Map 3D 2019.
Thank you.
pendean
Community Legend
Community Legend
To edit the pgp file in use by your session, at the command line, type this:
(startapp "notepad" (findfile "acad.pgp"))
Don't forget to reload he PGP file with REINIT command.
Or save the following as a LISP file and use it:
(defun c:gp(/ pgpfile);command alias editing
(setq pgpfile (strcat "notepad " (findfile "acad.pgp")))
(setvar "re-init" 16)
(prompt "\nACAD.PGP...reinitialized. ")
(princ)
) ;end
