We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
WFS Connection Issue
MichaelTaylforth5574
Message 1 of 27
Having an issue viewing data when successfully connected to WFS.  Connection is ok, however there is no data showing.  See below.
I can connect successfully to service using QGIS - see screen shot below.  I've just tried using the 2019 release and still no joy!!
I have found a limitation with WFS and MAP here https://knowledge.autodesk.com/support/autocad-map-3d/troubleshooting/caas/sfdcarticles/sfdcarticles...
Not sure if it is relevant.
Any clues?
Cheers,
Michael.
Connected to WFS but no dataConnected to WFS but no data
WFS layers showing correctly in QGISWFS layers showing correctly in QGIS
Replies (26)
Message 2 of 27
Pointdump
Michael,
Can you post the link that's giving you difficulties?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 27
Message 4 of 27
Pointdump
Michael,
Yup, getting same as you. (I used the free Gaia instead of QGIS.)
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 27
Cheers Dave, at least I can be (reasonably) sure it isn't somthing I'm doing wrong at my end...
M.
Message 6 of 27
WarrenGeissler
That's odd - the MAP Schema editor can SEE the schemas:
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Message 7 of 27
Koesti
Autodesk Support
Autodesk Support
Hi @MichaelTaylforth5574 and all,
performing some test I see the same behavior.
Connection is done but no Schema is visible - happens with all versions of WFS.
Therefore I document the behavior as change request and keep you updated.
Kind regards
Brigitte Koesterke
Technical Support Senior Specialist
Message 8 of 27
serguei
I have tried in Map 3D 2020, the issue has not been fixed. Connection is done but no Schema is visible
https://services.slip.wa.gov.au/public/services/SLIP_Public_Services/Property_and_Planning_WFS/MapSe...
Message 9 of 27
ChicagoLooper
Couldn't connect either. But I could connect using WMS.
WFS connection: Yes. (WMS: No, cannot connect)WFS connection: Yes. (WMS: No, cannot connect)
Chicagolooper
Message 10 of 27
Koesti
Autodesk Support
Autodesk Support
Hi @MichaelTaylforth5574 ,
I like to close the loop for reading WFS coming from ArcGIS 10.6.1 is not working.
Please install Fix for Ma3D 2020 from AKN which solves the issue and reads the data from provided WFS.
Regards
Brigitte Koesterke
Message 11 of 27
Hi Brigitte,
Thanks, however that link in your message doesn't work.
Regards
Michael.
Message 12 of 27
luc_vanlinden
Hi
As this is issue exists already for a LOOOOOOONG time, it would be appropriate to have this fix also available for Map 2018.
Luc Van Linden
Message 13 of 27
Hi Brigette, pls disregard my earlier post regarding the link to the fix.  All good.  Thanks, Michael.
Message 14 of 27
Jam_BK
Hello Brigitte,
I'm stil having issues with many WFS Connetcions... Most of them are just not displayed when connetced. For Example:
https://geoportal.umwelt.sachsen.de/arcgis/services/natur/issand_lebensraumtypen/MapServer/WFSServer
https://geoportal.umwelt.sachsen.de/arcgis/services/natur/natura2000/MapServer/WFSServer?
Do you have any suggestions?
Message 15 of 27
Koesti
Autodesk Support
Autodesk Support
Hi @Jam_BK,
Thanks for the WFS URLs.
There are a lot of different WFS services out and from my experience, the cause is very different.
With my tests, I was able to read the data by using the option to INVERT AXIS before adding to Map.
Regards
Brigitte
Brigitte Koesterke
Message 16 of 27
Koesti
Autodesk Support
Autodesk Support
Hi @Jam_BK ,
to be precise:
Only the second URL work for me - the first URL is not readable in any program I try.
Regards
Brigitte Koesterke
Message 17 of 27
Jam_BK
Hello Brigitte, thanks for your quick response!
It's strange, because i don't get any reply from the server... I tried inverting the axis, but that was not the solution either. I've already applied the hotfix   Map2020_WFS.zip, so right now I'm a little clueless. You have any ideas?
Message 18 of 27
Jam_BK
You're right, the first URL is outdated. Sorry my bad.
Message 19 of 27
Pointdump
Brigitte,
"INVERT AXIS"??
Where is this option, and what does it do?
Dave
Dave Stoll
Las Vegas, Nevada
Message 20 of 27
Koesti
Autodesk Support
Autodesk Support
Hi @Jam_BK ,
please find attached the dwg with the WFS connections which show the data for me - using BING maps to see that the location is fine.
Invert Axis - check before connect:
Regards
Brigitte Koesterke
