Unable To load Customization File
Every time I start up AutoCAD map 3D 2010, I get the following warning:-
Unable To Load Customization File:
P:\------\------\Piping.Cuix
That Customization Group Already Exists
Can anyone tell what I need to do to stop this warning appearing?
Cheers
andrewpuller3811
This will occur when a customization file is loaded twice.
Usually occurs when an enterprise cuix loads a cuix as a partial customization file and then the main cuix tries to load the same one.
You will need to go into the CUI editor, check whether a cuix file is being loaded twice and unload one of them. (right click and select unload)
If you have an enterprise cuix you might check with someone in your company, if you're not the cad manager or in IT.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
go to start>> AutoCAD 2010>> Reset Setting to Default. after Reset start AutoCAD again.
