Total length of Polylines
anna_pa
Message 1 of 19
anna_pa
How can I get the length of a Polyline from my drawing?
I want to get the length of the Polyline in km, because the polylines represents streets.
Best regards
Replies (18)
Message 2 of 19
parkr4st
select a PLine, the length will be in the properties ( Ctrl1)
dataextraction will gather the data from all the selected elements of the drawing and put the output into a table
as for the km,  the dwg units are km?
Message 3 of 19
braudpat
Hello
Since a long time, I am using this beautiful French routine from Patrick ...
TLENGTH is able to give you the Length off ALL AutoCAD Objects: Line, Arc, Circle, Ellipse, SPline, 2D/3D PLine, MLine, MPolygon, Region, etc ...
You can easily modify the routine to filter objects: select only LWPolyline for example
To load the routine: APPLOAD <Enter>
To run the routine: TLENGTH <Enter>
Happy WE, Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 19
АлексЮстасу
Alexander.Rivilis GeomProps.zip - total lenght in Properties palette.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 5 of 19
braudpat
Hello Anna
1) So with TLENGTH Lisp routine (see my 1st message), you get the Total Length of objects in "current" units (mm ou cm ou m or km or etc)
2) I add the other versions: TLENGTH_100 and TLENGTH_1000
3) TLENGTH_100 divides the result by 100 so for example: cm to m
3) TLENGTH_1000 divides the result by 1000 so for example: m to km
4) I hope these 3 Lisp routines (from Patrick) wil help you !?
5) You can load (with APPLOAD) the 3 versions and after you will have 3 new commands: TLENGTH , TLENGTH_100 , TLENGTH_1000
6) PLEASE remind that these Routines are Lisp/VLisp routines, so they can ONLY interact with real DWG objects !
AND NOT with MAP FDO Objects coming from: SHP, SQLite, SDF, Oracle, PostGIS, ArcGIS, ArcSDE, etc ...
7) I will appreciate 2 real simple DotNet routines doing the SAME thing (Total Length / Total Area) with FDO Objects : ONLY the Total Length / Total Area (if applicable) of all FDO selected objects ... Nothing more ... Because MORE means MONEY !!
Regards, Patrice
Patrice BRAUD
Message 6 of 19
АлексЮстасу
Always available after download - GeomProps.zip
Message 7 of 19
АлексЮстасу
Kudos for Alexander.Rivilis 🙂
Now only I myself noticed - GeomProps recalculate with the necessary coefficients:
I always need free programs the Alexander.Rivilis - ExplodeProxy, selsim.
Message 8 of 19
jennya
Awesome! Thank you  АлексЮстасу
Message 9 of 19
АлексЮстасу
Awesome Alexander.RivilisSmiley Very Happy
Message 10 of 19
Can you advance lisp ( automatic copy total length )?
Thanks you very much.
Message 11 of 19
hi @braudpat
Can you update lisp ( automatic copy sum length )?
Message 12 of 19
braudpat
Hello
What do you mean exactly by : automatic copy sum length ??
THE HEALTH (Stay Safe), Regards, Patrice (The Old French EE Froggy)
Patrice BRAUD
Message 13 of 19
hi @braudpat
==> Yes. Eg.I want copy sum length to excel (not Ctr+C)
I wish you do detail lisp for me. Because I don't understand lisp. 😞
Message 14 of 19
Peter2_1
It would be great if there is a small information in English about the tools. The homepage and the current info is not that helpful for many users with limited knowledge in different langauges ...
AutoCAD Map 3D 2023 German / Oracle
Message 15 of 19
АлексЮстасу
Alexander.Rivilis is present in the forums - https ://forums.autodesk.com/t5/user/viewprofilepage/user-id/481027. You can write him a Private Message.
What exactly would you like to clarify?
Message 16 of 19
АлексЮстасу
The author, Alexander.Rivilis, answered me:
The language of the program interface depends on the AutoCAD localization.
Many other Alexander.Rivilis contacts are in the program archive in Readme.txt.
Message 17 of 19
Peter2_1
Info:
Alexander just added an English readme to the ZIp package
Thanks a lot!
Message 18 of 19
Peter2_1
@Anonymous
thanks, a helpful tool.
For "GeomPropsGetPerimiter" I suggest to consider:
- it should be Perimeter, not Perimiter
- maybe you could replace it with GeomPropsGetLength to be consistent with the display in the properties and to be consistent with the meaning - a line does not have a perimeter, it has a length
Have a fine time!
Message 19 of 19
Alexander.Rivilis
@Peter2_1
I agree that it is my grammatical errors. But this program have been using for 15 years and I would not want to change the names of commands and functions that are used.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
