SVY21 (EPSG 3414)
SVY21 (EPSG 3414)
Hi, I am using AutoCAD Map 3D to tranform current coordinate system to SVY21. I cannot find SVY21 in the library. Does anyone know how to do it?
Thanks a lot.
Siping
gluckett
Under Map Setup, use the Create Coordinate System to create a new one from scratch.
undefined
Thanks, gluckett.
After I tranformed the coordiantes in WGS84 to SVY21 using the way you taught me, I found the transformation is not perfect. For example:
WGS84:
Lat = 1.2803, Lon = 103.8504
SVY21:
x = 29900.2891, y = 29190.1725
However, the converter in http://dominoc925.blogspot.sg/p/svy21-coordinate-converter.html 's gets
x = 29901.023548426907, y = 29194.595522157477
Is there anything I missed here? Could you share your WKT for me to check? Thanks.
My WKT:
PROJCS["SVY21 / Singapore TM",
GEOGCS["LL84",
DATUM["WGS84",
SPHEROID["WGS84",6378137.000,298.25722293],
TOWGS84[0.0000,0.0000,0.0000,0.000000,0.000000,0.000000,0.00000000]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Transverse_Mercator"],
PARAMETER["false_easting",28001.642],
PARAMETER["false_northing",38744.572],
PARAMETER["scale_factor",1.000000000000],
PARAMETER["central_meridian",103.83333333333300],
PARAMETER["latitude_of_origin",1.36666666666667],
UNIT["Meter",1.00000000000000]
gluckett
I have already compared this reference with my setting. The only difference could be in SPHEROID
SPHEROID["WGS 84",6378137,298.257223563,
                AUTHORITY["EPSG","7030"]]
while in my WKT:
I could not find the SPHEROID "WGS84" with the same parameter in AutoCAD's library.
Thanks.
Siping
Type a product name
