Importing DWG files in GEMCOM GEMS
Dear AutoDesk Community,
I'm currently using Autocad map 3D 2015, and I'm using it do digitalize and georreference some maps that I've drawn.
After that, I need to export de polylines to do some 3D geological modelling, and for that, I'm using another software (GEMCOME GEMS 6.4).
The problem is that, everytime that i try to import the DWG file into GEMS, I get the following error.
My question is... Is there any proceeding I should be doing before exporting the polylines from AutoCAD?
Any help would me much appreciated.
Thank you.
parkr4st
from the  GEMCOM Site
Esri shapefiles can be imported as points, polylines, or polygons
apparently you can mapexport work to .shp with Map3D and import it into GEMCOM
dave
Thank you very much Dave! It worked.
Cheers!
