AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Stuck in Paper Space!
3 REPLIES 3
1880 Views, 3 Replies
Ever since I upgraded to Map 2015 I have regretted it because I can't get out of paper space. Why does that new button not take you back to model space and where are my tabs?
3 REPLIES 3
parkr4st
Options   Display tab    layout elements  is  "Display layout and model tabs" checked?
The button on the status bar is not working on my M3d.  the commands MODEL & PSPACE work ok.
dave
in reply to: parkr4st
Oh I thought it was MSPACE, like PSPACE and that switches to the 'Model' setting on the status bar but does nothing otherwise.
That's quite a bug to relelase!
Thanks, I got my tabs back and will use those instead.
Alfred.NESWADBA
For me the button is working (using Map 3D 2015 64bit SP3)
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
