AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Rounding of coupling nut
4 REPLIES 4
john_daues
540 Views, 4 Replies
I'm drawing a coupling nut, like so:
How do I get the rounding? (seen here on the left)
4 REPLIES 4
About 3D Modeling You'd better contact the basic AutoCAD forum - https://forums.autodesk.com/t5/autocad-forum/bd-p/706.
They know much better about 3D modeling.
Here, the forum is not for 3D modeling, but a mapping vertical application - Map 3D.
Perhaps you need to make a sphere of the desired diameter, put it on the end of the nut, and trim the nut.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
CADaSchtroumpf
in reply to: john_daues
If can help you ! A lisp for nut in DIN dimension.
You can adapt it with your dimension for your coupling nut
I like this idea. Attached is the dwg with the sphere. Now what?
I've tried TRIM, SLICE, and SUBTRACT but not getting it.
INTERSECT
Thank you for my training in 3D modeling! 🙂
But it is clearly better to ask advice from long-knowledgeable specialists about 3D modeling - on the basic AutoCAD forum.
