Regenerating Features
TomWilgaWH
TomWilgaWH
Hello all,
When modifying/moving random items on the map...for instance moving a label, or changing an attribute of a device, the software tries to, at random times, regenerate features which in some cases takes a really long time and cranks my disk active time to 100%...please see images.
Is there a way to disable the regeneration of features through the rules? Mind you this has been an "issue" way back since 2007.
Thomas Wilga
Engineering Technician
GIS Coordinator
Field Inspector
Welland Hydro-Electric Systems Corp.
WarrenGeissler
I've not seen this specific issue before - however issues like this are often linked to the Cache files getting overloaded. If you have not tried this yet - go to MAPOPTIONS - SYSTEM TAB and use the Clear Cache button. Hopefully that will help.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
TomWilgaWH
Hi Warren,
Thanks for responding. I do clear the cache often, however it does not make a difference in performance for us.
I did however go out and buy a solid state drive, which definitely helped the issue! The feature regeneration is faster by ten fold, but I do still seem to get lag during panning after doing a number of edits in the GIS.
Cheers
Thomas Wilga
GIS Coordinator
Field Inspector
WarrenGeissler
SSD's are definitely the way to go! I have seen performance issues when connected to an ESRI datastore and several edits. Do you continue to see a problem after you check in your edits?
Warren Geissler
TomWilgaWH
Once it's lagging, I have a tendency to check-in the features and then refresh features. Unfortunately it doesn't help most times.
Thomas Wilga
GIS Coordinator
Field Inspector
