"Drawing of Display Model in Map failed" - finally solved?
Message 1 of 1
Map 2018.0.1, German
The command "Generate Graphics ... " creates an error, when it is started the second or third time. This is documented in Knowledge Base:
https://knowledge.autodesk.com/support/autocad-map-3d/troubleshooting/caas/sfdcarticles/sfdcarticles...
The defined "solution": close the windows and try again ...   Man Frustrated
For me this is not a solution, this is a bad workaround.
Is this issue already fixed in 2019 (or 2020 beta)? Or is there a better way to avoid it?
Have a fine eveneing!
Replies (0)
