Good Morning.
I am having the following problem in C3D 2015 and Map 2015:
Some tools from Map 3D does not open the corresponding dialog box.
The options appear on the command line as below pictures:
Has anyone ever experienced this problem? Anyone know what this is?
It is a variable filedia system.
The software has been updated correctly.
Thank you
Adriana
Solved by alexlibrelon. Go to Solution.
Solved by Murph_Map. Go to Solution.
Solved by olivier.eckmann. Go to Solution.
Adriana,
It sure looks like FILEDIA. What is yours set to?
Dave
Dave Stoll
Las Vegas, Nevada
No way, Olivier: it's a matter of missing "Support File Search Path" in the _OPTIONS interface, trust me.
Verify variable CMDDIA is set to 1
As the response of colleagues, Olivier and Murph.
Antonio,
I think there are two problems here. The "Define Object Data" problem, well, that one looks like CMDDIA, although I don't understand that command at all. The second problem, "Attach/Detach Object Data", I think you're onto something and I agree with you.
Stay a rebel, Antonio.
Dave
Dave Stoll
Las Vegas, Nevada
Hello
1) You must have : CMDDIA = 1
2) And you must have the Support File Path :
If ACAD MAP US/English : C:\Program Files\Autodesk\AutoCAD 2015\Map\Support\en-US
If ACAD MAP French: C:\Program Files\Autodesk\AutoCAD 2015\Map\Support\fr-FR
etc ...
Patrice BRAUD
Pat,
I bet in the Adriana's Autocad the variable CMDDIA is already set at 1, and do you know why?
Just because she wrote "Some tools..." don't work by GUI: if it would be set at 0, every tool should not work by GUI...
Hello Antonio
I imagine you bet RIGHT !
But they are so many special PATHs with MAP 2015 !?
Look at my MAP 2015 French Paths which are a little bit different with a MAP US/English, German, Spanish, Italian, Russian, etc ...
Please let me know your same Italian image !
Patrice BRAUD
Antonio,
I found this in the 2015 Help Section, >>Here<<:
To work around this issue, make sure the path to the ade.dcl file is set in the Support File Search Path.
Dave Stoll
Las Vegas, Nevada
Hello
I am a stupid boy because I know this bug ! ... Thks to Mr PointDump !
I was focusing on ACAD MAP but the problem is on ACAD CIVIL and if the MAP paths (specific for each language) are not correct, you will have problems (on CIVIL) with many MAP commands: MAPOPTIONS, MAPTRIM, ADEQUERY, etc
So please look at the right CIVIL 2015 FRENCH paths !
You must adapt the paths to an US/English, Italian, Spanish, German, etc ACAD CIVIL ...
Patrice BRAUD
Dear Dave & Pat,
I'm saying it's a path issue since my very first post in this thread, so I'm glad you're (slowly) beginning to understand what's up...
Antonio Vinci, the man, the myth, the legend! My unworthy self begs your forgiveness!
Dave
Dave Stoll
Las Vegas, Nevada
The support file path issues is one for Civil3D not having the path for the map3d tool(s). CMDDIA effects some of the map tools that are still from the old days and not updated to the newer dot net prorgaming, IE the Object data tools and a few others that i can't recall right now.
I've been looking for this solution as well (and I've just posted a request for help).
In my case I was missing the Define Query Dialog Box.
The reply by Dave Stoll (Pointdump) hit the mark.
For some reason the pointer to the Map Support folder does not seem to be automatically included in the support files list when you install Civil 3D.
As soon as I added this pointer up popped the dialog box.
Problom solved.
Thanks all.
