Problem importing KML label into AutoCAD
GAURAV.KHODIYA_AGEL
Message 1 of 16
GAURAV.KHODIYA_AGEL
When i try to import kml into AutoCAD Map 3d 2020 points get imported but their labels are not imported.
Name attribute is not visible (Screenshot attached)
Replies (15)
Message 2 of 16
Pointdump
Gaurav,
Welcome to the Autodesk Forums.
Can you post your KML? (Zip first)
A couple of things to try. Under Data click the ellipsis to the right of <none> and check the radio button that says "Create object data".
Click on "Driver Options" and see if anything needs to be turned on. It's usually greyed out with most SHP Imports, and yours is not.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 16
braudpat
Hello @GAURAV.KHODIYA_AGEL
+1 with @Pointdump
Please look at the French joined Image of MAPIMPORT ...
THE HEALTH, Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 16
GAURAV.KHODIYA_AGEL
Dear Dave,
Thanks for your valuable inputs.
I have tried Data Option & Creating Object but no fields can be seen (Ref. Attached Image 1)
Secondly i even tried Driver Option but no relevant options were found (Ref. Attached Image 2)
I have imported label from shapefile, but guess importing kml with label is tricky.
I am attaching KML in zipped format for your reference.
Gaurav
Message 5 of 16
braudpat
SORRY but your KMZ / KML is empty ! There are only 6 XY Points with "almost" ZERO Data !
Please look at the 2 Images : MAPIMPORT from ACAD MAP and the QGIS Image ...
Patrice BRAUD
Message 6 of 16
braudpat
Hello
Into QGIS you can see A1/A2/A3/A4/A5/A6 Infos so from QGIS 3.10 , I have exported the KML/KMZ to SHP ...
AND NOW you can MAPIMPORT my SHP ... And get the A1/A2/A3/A4/A5/A6 Infos ...
Patrice BRAUD
Message 7 of 16
GAURAV.KHODIYA_AGEL
Dear Patrice
Thanks for your prompt and very informative response.
The issue i am facing is when i try to import KML with label into AutoCAD Map 3d, with shapefile as you have mentioned in your reply it can be done. And I dont have access to ArcGIS or QGIS software.
In GIS software we get Name attribute field which contains label data but in AutoCAD it is not available (ref Attached Image 22)
Is there anyway this can be done solely using AutoCAD Map 3d
Regards
Gaurav
Message 8 of 16
braudpat
Hello
I think you have to use a freeware (QGIS or other) to convert your KML/KMZ to Shape files ...
Then the AutoCAD MAP MAPIMPORT from Shape will be OK !
Maybe somebody else will have a brillant idea !?
Nice polygon of about 70 231 square meters ...
Patrice BRAUD
Message 9 of 16
ChicagoLooper
Your kmz consists of six points in Bhojay. The points are named A1 through A6. You would like to use MAPIMPORT to bring in the points and label them with their point name.
You can’t use Mapimport in Map3D to bring in kmz’s (or kml’s) with their point names. The Mapimport command will not ‘read’ the kmz’s (Placemark) data so  it’ll just bring the the geometry, or the point itself.
To bring the points in along with their point names you’ll need to use third party software (not Goggle Earth Pro) and re-create your six points in another format such as shapefile. Alternatively, you may bring your kmz into a third party software and export your kmz file to shapefile.
<<QGIS, ArcMap, Arc Pro, Global Mapper are some examples of third party software.)>>
Mapimport has the option to retain the shapefile’s attribute data by converting it to Map3D’s Object Data. In addition to using Mapimport, you may also bring in the shapefile using M3D’s Data Connection and label the points using the shapefile’s Name attribute
Kmz and kml formats have limited options when executing Mapimport in M3D.
Chicagolooper
Message 10 of 16
shallowhead
There is a FDO Provider to import the names, etc of kml or kmz files here:
http://www.sl-king.com/fdokml/download/download.html
But I wrote the author and he wont be making a new provider for newer autocad version anytime soon.
It is available free for acad map 3d versions 2013 and earlier.
I've also searched for other FDO providers for newer versions of acad on the web but so far no luck.
KT
Message 11 of 16
АлексЮстасу
You can MAPIMPORT points with label==kml_name from kml/kmz.
1. To create the point block with the attribute which is called "kml_name". The case in the name is important! When creating a block, you need to change to small letters twice.
2. With MAPIMPORT, you must go to Driver Options, press "+" at Shema Attributes and click "..." - enable kml_name.
3. For Placemark (your points), select the newly created block instead of <ACAD_POINT> and load attributes.
Note 1: You can immediately attach to the points Object Data (see the Data column) where the points names will be stored.
Note 2: Settings can be saved in Saved profiles in * .ipf.
Note 3: For some reason, kmz for me is not imported into 2019, if a coordinate transformation is needed.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Message 12 of 16
shallowhead
Alexander,
Very nice! Thanks man!
Message 13 of 16
Alan_Marshall1
Very helpful - thank you!
Message 14 of 16
FJankovsky
@АлексЮстасу
Great information.
Thank you.
Message 15 of 16
jdefisher
This helped me get 50 kml_name labels from their corresponding placemarks into CAD! Thank you!
Message 16 of 16
tcorey
Thank you, Alexander, for The Great solution.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
