Placing points or extraction point coords at vertices
Good day, I was wondering whether anyone out there knows or has a lisp program that inserts points with their respective names at vertices within model space. As well as exporting these created points to an excel file.
Kind regards
Muse
АлексЮстасу
Hi, Muse,
What do you mean by "points" and "their responsive names"? COGO, Points + Texts, blocks with attributes?
You can insert regular points/blocks into vertices - PTManager.lsp, PTM from LeeMac:
1. Upload the PTM polyline to a txt file.
2. Load PTM these txt as dots/blocks.
If you want a block with an attribute, you can add the appropriate numbers to txt after the coordinates, and these numbers will be in the attributes.
You can _MAPEXPORT export to Excel in mif/mid, PoinTManager.lsp, PTM from LeeMac.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
