I had a toolbar for Multiline (MLine) which had tools for style draw etc. I have had to re-instal Map3D due to a corrupt add in and now I cannot find said toolbar to add to the ribbon. I have tried searching and can find no clue anywhere. Is this an anti-mline conspiracy ??
Solved by ChicagoLooper. Go to Solution.
Solved by bjohncarmichael. Go to Solution.
Could it have been a custom toolbar? I just went back to the 2016 version, and I don't see any stock, built-in MLINE toolbar.
Thanks for replying, I am on 2015 but I can't remember where it came from, I cant find it my available toolbars anyway !
You'll need to perform MLINE command from the command line.
Alternatively, you can create a Custom Tool Palette and place the mline command there.
Enter CUI on command line=>In search box enter 'MULTI'=>Results from your search will appear=>Click-and-Drag the Multiline command directly onto your tool palette.
There is no inline image or anything attached.
Sorry, the reply was sent by email without an attachment.
Many thanks for your time, that must have been how I did it before but I can't remember doing it ! Oh isn't age a wonderful thing ??
Thanks again, John.
