AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Query error
3 REPLIES 3
776 Views, 3 Replies
Query error
We have been having difficulty doing co-ordinate transformations from one drawing into another since out I.T. installed Windows 7 on our systems (complete system wipe and rebuild), we get the same error on each workstation, both in C3d 2009 and 2011.
Command: _ADEQUERY
Executing query...
Querying from P:\Geomatics\198 Imperial Oil Resources\198.04.01\Nabiye (All NB
Projects)\Phase 2 IFS & Estimates\Pad Calcs\Nabiye Pads Precalc.dwg ...
Executing location query...done.
Displaying queried objects...
0 object(s) have been queried.
Command:
the Map Message box says simply
"some entities from .... can't be queried
eFilerError
error log attached.
I've heard through the grapevine there is supposed to be a simple fix for this, but I have not found out yet. Any ideas?
3 REPLIES 3
Are you query Civil 3D objects or standard AutoCAD objects? The map query
does not work on C3D objects.
Murph
http://map3d.wordpress.com/
wrote in message news:6393396@discussion.autodesk.com...
Command: _ADEQUERY
Executing query...
NB
Command:
eFilerError
error log attached.
vaughan.giles7AGEV
If you cannot Query Civil 3D objects, how do you perform a coordinate conversion on them?
*The solution in my instance was to explode the surface model, retaining the contours and the surface model boundary.
Then I was able to perform a MAPWSPACE coordinate conversion via the QUERY function, then after converting to the correct coordinate system I simply re-created the surface model, using the contours and boundary.
