Oracle, Industry Model
Situation (as usual):
I have a Wastewater-Industry Model "City A" with label_definitons and a style definition (display model), simplified like this:
Now I want to use the same style definition (display model) for a similar industry model "City B", but there are other IDs used:
Is it possible and "allowed" that I modify the IDs in "City B" to be the same as in "City A"?
Solved by Peter2_1. Go to Solution.
I do not think there is a simple solution to change label_def_id.
label_def_id stored in table TB_LABEL_DEF in field ID.
http://help.autodesk.com/view/MAP/2020/ENU/?guid=GUID-E3969EAD-73FB-482F-9A21-1A83F0CD78DB
You can't just change ID in this table. It is based on a sequence tb_labeldef_s.
(also interesting about tb_labeldef_s: http://raumpatrouille3d.blogspot.com/2013/11/tblabeldefid.html )
I'm not saying it is not possible to change the ID, but there are certainly things to consider. I would have great doubts doing this.
I have not tried it, but maybe this approach would be possible:
Do not use TBL-table in display modell.
Use a view (based on TBL-table) instead. (up to here I can say that it works; we often do that).
The view is based on TBL-table and additionally contains field NAME from table TB_LABEL_DEF.
In display model query field NAME of the view.
Regards
Jens
Hi Jens
thanks for your detailed information. In the meantime I started a support-case; let's see if there will be ways to go without problems. I will report ..
A solution, completely new documented here:
Did someone make already some experience with this solution to report it here?
@swt-gis schrieb:I do not think there is a simple solution to change label_def_id.
(also interesting about tb_labeldef_s: http://raumpatrouille3d.blogspot.com/2013/11/tblabeldefid.html ) ....
I want to reactivate these details again.
In my test-scheme I did 2 things relating for pipes
What happened:
So anyone here who can confirm it?
Have a great weekend!
