Missing Menus in 2020
buschdave
buschdave
In past versions of Autocad Map 3d when I ran adequery or adekeyview for example I would get a detailed on-screen menu. Now in 2020 all I get is a partial command line.
Filedia = 1 Cmddia=1 Dynamic Input is Off (when On get same command line next to cursor)
I would like the menus back if they are still available. Hopefully and probably something simple. Help please?
georg.grebenyuk
Hi, David
May be you want say about command "MAPWSPACE" and turn on it in command line.
Best regards,
Egor Grebenyuk,
JSC "Roszheldorproject", BIM specialist (infrastructure)
buschdave
Mapwspace is on - still no change when running adequery
Gary_Braun
You may want to check your support file paths and make sure the MAP folders are being referenced.
O_Eckmann
buschdave
Paths in example were there but ade.dcl was found somewhere else under user folders. Works now. Thanks for the example.
