Dimaligned shows unit format different from system unit format
In Autocad, my units are in decimal format, but when I use the dimaligned command, the units are in feet/inches/fraction format. How do I change the format on the dimaligned command so it shows decimals?
user181
Use the command DIMSTYLE and select Modify on the right side of the dialog box and then go to the primary units tab of the next dialog and change Unit Format to decimal
Thank you!
