06:37 AM
Hi there,
The Autodesk Connector for ArcGIS is great but I am wondering if it is possible to connect to an ArcGIS MapServer or FeatureServer that is not made available through Portal for ArcGIS?
Previously, this was possible through the ArcGIS for AutoCAD plugin. Has the plugin now been replaced by the Autodesk Connector for ArcGIS?
Ideally the functionality to connect directly to ArcGIS Services (rather than via a Portal) would be built in to the Autodesk Connector for ArcGIS as even if the ArcGIS for AutoCAD plugin is not deprecated it is awkward for users to have to install it.
Many thanks,
David
