Hi @Land337
Based on the parcel data you uploaded, you have exactly 10 parcels, 5 western parcels and 5 eastern parcels with Old River Road dividing the west from the the east. Do you want to combine the acreage of for each TRACT? I ask, because you didn't clearly explain exactly what you want to achieve.
Don't make the mistake of describing the workflow you think will work or a workflow you've already tried because it may not be a practical way to get what you want. Describe, as clearly as possible (the more details the better) your end goal, then let the forum figure out how to get there.
If you simply want to combine AREA, then a possible workflow would be:
- Calculate or determine the area for each individual parcel.
- Identify the Tract Number.
- Add (combine) the the Area for for parcels that have the same Tract number.
I wouldn't MERGE the parcels. Keep them separate. If you merge, you may lose data. You don't want to lose or overwrite data, you want to MANAGE the data, and if needed, create new data, which in your case would be Total Area per Tract.
Chicagolooper
