Mastermap.dwt
Mastermap.dwt
Mastermap.dwt
I've been trying to find a source for the MasterMap.dwt template, it seems to be missing from the location usually voted.
Can anyone help?
Alfred.NESWADBA
May I ask why you think that this file is part of Map3D?
Or are you referring to a template from a 3rd party application/plugin?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
I've been trying to load mastermap into map 3d. Map 3d will load it but the some of the layers don't display correctly. Looking at forums it appears that there is, or was, a template, which could be downloaded from Autodesk (https://forums.augi.com/showthread.php?128087-OS-Mastermap), but the link suggested returns a 404.
Alfred.NESWADBA
What is "mastermap" in other words? What do you have and how do you load it into Map3D. And why do you need a template when you already have a file with that content?
For now I even don't know what you are referring to.
Do you mean "CAD-Layers" (command _LAYER) or GIS/FDO-Layers (command _MAPCONNECT)?
And when you say "don't display correctly" ... what do you see, and what do you expect to see?
- alfred -
Alfred NESWADBA
WarrenGeissler
@Alfred.NESWADBA  - Gordon is talking about downloadable UK GIS data from Ordnance Survey (OS Mastermap). Autodesk UK used to have an AutoCAD template available for download that you could use for layer / block mapping when importing the data. It appears that template is no longer available.
@Anonymous - You may also want to post a request for a copy of that template on the AUGI forum. Also - it might be worth it to ping Ordnance Survey >>HERE<< to see if anyone there has it.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
