AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
MAPEXPORT nothing shows in Dialog box - see screenshot
9 REPLIES 9
Message 1 of 10
703 Views, 9 Replies
It showed up the first time and now nothing shows in popup window. I tried installing and reinstalling several times. Am using Map3D 2019 and even tried 2018 version. What is going on?? very frustrating
9 REPLIES 9
Message 2 of 10
Alfred.NESWADBA
does the same happen when you start _MAPEXPORT and select SDF as filetype?
Which SHP filetype did you use, "Shape multiclass" or "ESRI shape"?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 10
in reply to: Alfred.NESWADBA
Yes, the same happens even when I select SDF as the filetype.
Message 4 of 10
O_Eckmann
You could try to remove (or rename) "MapExport.ini" file to force AutoCAD to recreate one. You could find it in
"C:\ProgramData\Autodesk\Autodesk AutoCAD Map 3D 2018\R22.0" for MAP 3D 2018.
Remove this file when AutoCAD is closed.
Olivier
Olivier Eckmann
Message 5 of 10
in reply to: O_Eckmann
Olivier,
Thanks for the suggestion. I removed the MapExport.ini file closed Map 3D then reopened and tried the MAPEXPORT command. It still shows the same blank popup screen dialog box. I even tried uninstalling and installing different versions of Map 3D and Civil 3D. Maybe worth mentioning is that when I first tried MapExport the very first time, it worked correctly and showed the selection dialog box correctly. Every subsequent try after that did not show anything in the popup screen.
Any other suggestions are greatly appreciated.
Anthony
Message 6 of 10
Alfred.NESWADBA
when you login to your workstation with a different Windows user account and start Map 3D in that context ... working well?
- alfred -
Alfred NESWADBA
Message 7 of 10
Hi Alfred,
Not sure I know what you mean, can you elaborate? I have a standalone version. Should I try logging out then in again?
Message 8 of 10
Alfred.NESWADBA
if you run AutoCAD with your own Windows login, then all settings based on your login (AutoCAD profile, registry settings, settings in your <users>-folder are always the same ... and so if there is a defect you might see the reason.
That's why I suggested to create a new Windows user account on your system, login with that new user account (so all settings are like a new installation of AutoCAD Map 3D) and try now to run _MAPEXPORT.
If that works well we know that we need to reset your AutoCAD settings to default for your original user account and - sorry about that - you need to do your customization's again. But then you know it's worth to do that.
- alfred -
Alfred NESWADBA
Message 9 of 10
O_Eckmann
Just for a try, I join my MapExport.ini from MAP 3D 2018. You could try with this file.
You say you have Civil3D and MAP3D installed. Is it same version?
I read MapExport.ini doesn't have same parameter between Map3D and Civil 3D for entity type because with Civil you could take into account aecc object.
Olivier
Olivier Eckmann
Message 10 of 10
JC-OUAKNINE2
Hello
please try this solution post in message 3/5.
https://forums.autodesk.com/t5/autocad-map-3d-forum/map-3d-commands-problem-and-reinstallation-after...
Good luck.
Jean-Christophe OUAKNINE
