AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Mapbook Rotating Sheet Layouts (Dynamic Sheet Layouts)
3 REPLIES 3
675 Views, 3 Replies
I am trying to figure out a way to get Mapbook to create sheet layouts that are rotated to fit a custom tiling scheme.
In other words, if I have placed sheet border tiles along a road, is there a way to automatically produce plans with viewports rotated to fit these tiles?
Thanks!
3 REPLIES 3
gluckett
If you choose the Custom Tiling scheme and choose those polygons, you can then go into the selected Layouts and rotate the viewport after the fact. Or within the view port you can do a DVIEW - TWIST
in reply to: gluckett
Thanks gluckett,
That is quite helpful although I am still wondering if there is a way to auto-rotate all layout viewports as I have over 400 sheets. I am fairly certain that this is possible within Civil 3D but I have yet to find a way within Map...
prayogac
HI mr Henrywross
it seems that you want to generate plan map from your profile??
if so you can use the benefit of automation plan & profil production in civil 3d,you also can  produce the plan map only too
im sory about my lack of english i try my best,thnx u
Tags (1)
Technology Administrators
