I am trying to figure out a way to get Mapbook to create sheet layouts that are rotated to fit a custom tiling scheme.
In other words, if I have placed sheet border tiles along a road, is there a way to automatically produce plans with viewports rotated to fit these tiles?
Thanks!
Solved by prayogac. Go to Solution.
Thanks gluckett,
That is quite helpful although I am still wondering if there is a way to auto-rotate all layout viewports as I have over 400 sheets. I am fairly certain that this is possible within Civil 3D but I have yet to find a way within Map...
HI mr Henrywross
it seems that you want to generate plan map from your profile??
if so you can use the benefit of automation plan & profil production in civil 3d,you also can produce the plan map only too
im sory about my lack of english i try my best,thnx u
