Ligar pontos automático
Como faço para ligar os pontos automaticamente no Autocad?
Normalmente eu faço o alinhamento (SPLINE). Faço o comando Measure para conseguir os vértice. Preciso unir ester vértices com uma Polilinha
How do I connect points automatically in Autocad? I do the alignment (SPLINE). But I need the vertices
Alfred.NESWADBA
AutoCAD does not have a function to connect points.
You can start command _PLINE and use object snap _NODE to connect them
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
АлексЮстасу
You can use PtManager.lsp from Lee Mac:
1. Save points to txt-file
2. Load polylines on these points
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Pointdump
Marcelo,
Welcome to the Autodesk Forums.
You can use an old-fashioned AutoCAD Script:
SPLINE
722100.6314,26768173.23,1183.52
722102.624,26768177.99,1182.08
722088.8445,26768178.91,1181.12
722067.2015,26768189.57,1180.16
722011.1855,26768196.39,1179.19
722013.6465,26768201.83,1178.71
Make sure your last line is a space. Save in NotePad, then change the TXT extension to ".SCR" extension. Use the _SCRIPT Command to generate the Spline.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
