AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
length of multiple lines
7 REPLIES 7
Message 1 of 8
537 Views, 7 Replies
I have 400 lines and need to fine the total length of all the lines.
7 REPLIES 7
Message 2 of 8
Alfred.NESWADBA
you can either search for some tools doing that or start command _DATAEXTRACTION (>>>details<<<) and export the length of these lines. Use then e.g. Excel to built the sum.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 8
braudpat
Hello
You are speaking about standard ACAD Lines, PLines, Arcs, etc ?
OR
FDO Lines/Plines ?
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 8
antoniovinci
Moreover, you can _MAPEXPORT all to a linear shapefile, adding the OD "Length" attribute.
Then you open the resulting .DBF in a spreadsheet (like Libreoffice) and sum the Length column (as said by Alfred).
Message 5 of 8
in reply to: Alfred.NESWADBA
thanks
Message 6 of 8
Murph_Map
Another option, download tlen.lsp from here.
Murph
Supporting the troops daily.
Message 7 of 8
braudpat
Hello
"TLEN.lsp" from Tee Square is OK but TLEN is running on : Line, Arc, Pline, Circle, SPline, Ellipse
So since 2009, I am using a French Routine "TLENGTH.lsp" (which is more complete - Author: Patrick_35) because TLENGTH is running on :
"LINE,POLYLINE,LWPOLYLINE,ARC,CIRCLE,ELLIPSE,SPLINE,MLINE,REGION,MPOLYGON"
Patrice BRAUD
Message 8 of 8
antoniovinci
in reply to: braudpat
Merci beaucoup, Pat, I guess that's what Alfred was talking about when he wrote "search for some tools doing that"...
Technology Administrators
AutoCAD Beta
