AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
KOSOVAREF01 coordinate system
15 REPLIES 15
Message 1 of 16
burim.azemi
1546 Views, 15 Replies
KOSOVAREF01 coordinate system is not included yet in AutoCAD.
We are using only this coordinate system, and please if anyone can help me to use this coordinate system with AutoCAD Map.
15 REPLIES 15
Message 2 of 16
JC-OUAKNINE2
in reply to: burim.azemi
If I could help you, I have made a PDF about using  the command MAPCSCREATE,
it's in french langage, follow this link https://georezo.net/forum/viewtopic.php?id=84519
message 19 & 20.
Jean-Christophe OUAKNINE
Message 3 of 16
burim.azemi
in reply to: JC-OUAKNINE2
I couldn't find the PDF in the link you sent
Message 4 of 16
JC-OUAKNINE2
you have to sign in to the site.
Else, I could give you link to download files.
Message 5 of 16
braudpat
Hello @burim.azemi
I have joined the @JC-OUAKNINE2 PDF !
---- And MAYBE you will find some useful Infos here :
---- Creation coordinate system with affine transformation when impossible use geodetic transformation ----
---- Mar 21 2020 ---- ACAD MAP & ACAD CIVIL ----
https://knowledge.autodesk.com/support/autocad-map-3d/learn-explore/caas/simplecontent/content/creat...
---- Autodesk University 2019 ---- CES322656 ----
---- Beyond State Plane: A Look at Custom Ground Coordinate Systems in Civil 3D/ AutoCAD Map 3D
https://www.autodesk.com/autodesk-university/class/Beyond-State-Plane-Look-Custom-Ground-Coordinate-...
Video + Handout + Presentation
---- Finish Strong Friday: Custom Ground Coordinate System in a Lambert Conic State ---- 11 nov 2017
https://youtu.be/4D9gzSmKeDY
---- AutoCAD Civil 3D Grid Ground Transformations Part 1. Cogo Points ---- 11 avr 2012
https://youtu.be/O2jWuPDjVb0
---- AutoCAD Civil 3D Grid Ground Transformations Part 2. Survey Database ---- 11 avr 2012
https://youtu.be/wl84WCV7BHo
---- AutoCAD Civil 3D Grid Ground Transformations Part 3. Drawing Data ---- 11 avr 2012
https://youtu.be/ceKHY64Xt1U
The Health, Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Using the 'mapcslibrary' command, I show a technique for creating a ground coordinate system for a project collected using pseudo-ground state plane coordinates. This technique simply scales the grid values of the state plane data to simulate ground values. In this video, I show doing this for a ...
Techniques for dealing with grid/ground with respect to drawing data (DWG and DGN).
Techniques for dealing with grid/ground with respect to the survey database in Civil 3D.
Techniques for dealing with grid/ground with respect to cogo points in Civil 3D.
Message 6 of 16
JC-OUAKNINE2
in reply to: braudpat
@braudpatis so gentleman to give us all links
speaking about MAPCSCREATE Masterclasses method !
That's Great !
Message 7 of 16
burim.azemi
Thank you very much braudpat.
I will try to translate it from French to English.
Message 8 of 16
Pointdump
Hi Burim,
I used MAPCSCREATE to create a Custom Coordinate System based on Parameters from >>>Here<<<. When you open the attached drawing it will ask if you want to add KosovaRef01 to your MAPCSLIBRARY. Click Yes and you're off to the races.
Use MAPCSLIBRARY >> View to look it over.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 9 of 16
burim.azemi
in reply to: Pointdump
Thank you very much Dave for your effort.
You can find attached Kosovo borders and main roads to compare with Kosovo borders you sent.
I think it is problem only with one point to regulate the whole territory of Kosovo, because with MAPCSCREATE you can give only one location point.
However, I greatly appreciate your desire and effort for help.
Message 10 of 16
Pointdump
Burim,
"...problem only with one point to regulate the whole territory of Kosovo..."
I think there's other things at play here. I found another shapefile of Kosova that is 3000 Meters different than the one I used for that drawing. Is it spelled "Kosovo" or "Kosova". I've seen it both ways.
Your road data looks like it's shifted 470 Meters south of Bing Live Maps. Where did you find your linework? Can you post a link so I can do some testing?
A good test would be to compare Official Survey Monuments with hard coordinates. Do you have any of those?
Dave
Dave Stoll
Las Vegas, Nevada
Message 11 of 16
burim.azemi
Hi Dave,
Internationally it is known as Kosovo, but locally as Kosova.
Our linework is prepared by our company based on orthophotos from year 2009 from Kosovo Cadastral Agency, so you can not find them elsewhere, but the linework I send are OK and are based on KosovaRef01 coordinate system.
The problem is that we don't want to use anymore old orthophotos, but instead we want to use Google/Bing maps as background.
Can you explain more, please, about Official Survey Monuments with hard coordinates, what you mean with that.
Message 12 of 16
Pointdump
Burim,
Official Survey Monuments are points with published coordinates. Like brass discs or concrete monuments where a surveyor would start his survey from.
I think I have the shift figured out. The Spatial Reference listing for KosovaRef01 shows a Gauss Kruger Projection, in which Map 3D doesn't let you note the 0.9999 Scale Factor. So I'll need to change the Projection from Gauss Kruger to Transverse Mercator. If you multiply the Northing by 0.0001 it's about the amount of the shift. I'll test it.
Dave
Dave Stoll
Las Vegas, Nevada
Message 13 of 16
burim.azemi
Hi Dave,
I don't know that we have in Kosovo points with published coordinates.
Please, tell me, after you test projection with Transverse Mercator.
Message 14 of 16
Pointdump
Burim,
This gets you very close. I changed the Projection from Gauss_Kruger to "Transverse Mercator using Kruger Formulation" and added the 0.9999 Scale Reduction. Very close.
In MAPCSLIBRARY click the Edit Button and make these changes.
Dave
Dave Stoll
Las Vegas, Nevada
Message 15 of 16
Pointdump
Very close. And keep in mind that Bing Live Maps is not perfect. It is not exact.
Dave Stoll
Las Vegas, Nevada
Message 16 of 16
burim.azemi
You are my hero, Dave. You saved my life.
Thanks a thousand time.
I wish you all the best.
